I've not watched the video, but my opinion is that they might shoot up in value, but only for low mileage pristine examples. Servicing costs and general running costs will continue to be high and I don't believe that with the exception of a few models, anyone will ever break even or make money on a car if running costs are taken into account.
Broke down today!
Was joining the motorway off a short sliproad in lane 2, lorry in lane 1 so needed to haul arse before motorway traffic caught up. Doing good, nice progress, move into lane 3 as traffic ahead and just as I'm about to pass them the throttle cuts out! I'm now costing
Managed to coast the car to the hard shoulder through the traffic and attempt to start it back up. Engine fires up but within a second cuts out again. Applying throttle during startup yields no throttle response either, so immediately I'm thinking the engine isn't fuelling correctly or something along those lines.
I've had the post cat o2 sensor replacement booked for a while now so that is still yet to be done.
I ring RAC, man arrives within 45mins, I take some clown mask selfies in the meantime to keep spirits high.
RAC man does some things, tells me to stay safe. I stay safe.
I hear M3 come to life, he applies some throttle, I hear the exhaust blow me some RASPberries. Nice.
Turns out the MAF has died. by unplugging the MAF connector, the engine fires up fine, obviously running in reset/lean mode. Normally unplugging the MAF would cause the engine to cut out within seconds, not the other way round.
I now also believe my post cat o2 sensors are most likely fine, and it was the failing MAF skewing the other sensor readings. I'll pick up a Bosch MAF tomorrow and monitor and check to see if the o2 sensor ECU flag pops back up.
Aloha N is no good for regular driving as it's pretty rough. It also means I'd need to ditch the MAF and go MAP/IAT. So additional expense.
If I had SMG then I'd maybe consider the CSL software upgrade, but again way more expense than just what I have (Eventuri).
I'm actually really happy with it like this. The sound and feel is really amazing. I'd love more induction sound still, but the only solution for that costs nearly £3000![]()
Yeah that's what I mean, I'd have to have the extra expense to get the CSL or CSL style airbox, and then the Alpha N or CSL software and accompanying things to go with. Not really a viable option for a car with a manual gearbox mind.
I've tried starting the car just now with and without the MAF connected.
Connected = Car starts but cuts out within 2 seconds of idling at cold start rpms.
Disconnected = Car starts perfectly, and with a silky smooth idle.
My MAF is almost definitely dead!
I'll use daylight tomorrow to also check the intake boots between the plenum and eventuri, as the rubber on those can perish over time and cause vacuum leaks, might be worth just undoing the clamps on them too and check to make sure it's all seated correctly underneath.
