This looks like a memory issue at face value. X299 skylake X very few can run 4133Mhz in a stable manner. Check 4000 c19 1.45 on mems. One stick at a time installed so 8GB.
Also, as above, restore your defaults. If that makes no difference, also just try running with a single stick of RAM in the board, and cycles though the modules if you have trouble with the first one.
 )  all this time i was adjusting the CPU Input voltage it's actually the "CPU core voltage override" that was meant to be adjusted for the cpu cores this was left on Auto all the time. The clue was there "cpu core voltage" but just looked at the override word and left it on auto.
Well done for owning up! Just be grateful you didn't get the two mixed up and put 2v through the cpu! Alls well that ends well.First of all thanks to everyone that replied and a big big thank you to 8 Pack for trying to help me out.
Ok i put my hands up i messed up big time (know i look stupid which i deserve to) all this time i was adjusting the CPU Input voltage it's actually the "CPU core voltage override" that was meant to be adjusted for the cpu cores this was left on Auto all the time. The glue was there "cpu core voltage" but just looked at the override word and left it on auto.
This is what happens when you overclock after a few years.
Maybe I make a profile on apex, Rampage and ocf for these delid cpu then no issue like this arrises again.
