Install windows or wait
27 Mar 2016
Bristolian living in Swindon
Hi all
Built my Ryzen system last night but i still havent got a GPU to put in, Is it best to wait and fit GPU before installing windows or does it not make any difference.
Thank you
Not 100% my self but I `think` that there is no onboard gfx with Ryzen(Might have misread that somewhere )
Maybe plug it in and see if you get into Bios?
Nope. The display ports on the motherboard is only used if you have an APU installed. Ryzen has no IGP and the motherboard doesn't either so they pretty much do nothing.
So I'll have to wait until I get the GPU fitted... may purchase a 1050ti for now then
