Thin tops are the trend, especially with contemporary kitchen design.
We show all our Quartz in 20mm as we sell a modern product. We have a 12mm Coran display which looks superb on a handle-less kitchen. There is the added advantage of thinner being cheaper too!
Depends on the material, but I think simple works best. I'd say a single or a double pencil bevel, not a standard bevel.
Using this as reference.
I do think 20mm looks great in the right colour, but it's all subjective and also hinges on the unit style. I just wonder how long it will still look modern.
Sleek, handleless design? 20mm would be fine. Something more classic? I just don't think it'll work long-term.
Even laminate tops are becoming thinner now. I've got 16mm laminate available.
One thing I should mention about thinner worktops is that you need to be a bit cautious about hobs and sinks. If you have a gas hob above a set of draws on a 20mm top, the hob will sit inside the draw space by around 15-20mm. Gas hobs require a pipe connection and will likely mean you will need to cut a bit of the draw box to allow this to happen.
Some inset sinks could cause a problem if they are of a certain design and the drainer is intended to go above a washing machine or dishwasher.
i had anticipated the gas and that we might lose the drawer under it but not the sink
its an undermount sink and the drainer is meant to go above a washing machine
how can i work out if it will all fit or not?
If it is an under mount sink you will be fine as long as its a cupboard beneath and not draws. If you are planning on putting a bin system in there you might also come across problems. Just make sure the under mount sink is designed to fit within the size of sink unit you have.
