OcUK Staff
- 26 Nov 2014
- Stoke
Available right now, we have the brand new Phanteks Eclipse P300 in stock. The P300 is the smaller brother of the immensely popular P400, keeping a lot of desirable features whilst managing to hit an extremely competitive pricepoint. The P300 has a full tempered glass side panel, along with a completely metal exterior for a premium look straight out of the box. Something that's cool in particular is that the PSU shroud forms part of the exterior, meaning the system looks much cleaner as a result. This is rarely seen and I think it actually looks better than the standard PSU shrouds employed by most other cases. Inside we have sufficient space for ATX motherboards (E-ATX up to 275mm wide), 330mm VGA Cards, 160mm CPU Coolers, 197mm PSU's (including cabling) and a 280mm front radiator, along with a 120mm space at the rear, that is occupied by a Phanteks high performance 120mm fan. There is space for up to 4 x 2.5" drives, with 2 on the rear of the motherboard tray (1 of which requires the optional 2.5" SSD tray), and either 2 x 2.5" or 3.5" drives in the PSU shroud (accessible by removal of the front panel).
RGB lovers are not disappointed, with an RGB strip on the front part of the PSU shroud, along with an RGB power button, and compatibility with Asus Aura Sync, Gigabyte RGB Fusion and MSI Mystic Light Sync is included, along with all Phanteks RGB products (using the optional RGB Adapter that we offer, or included in the starter kit) Control is by a button on the I/O panel, which also has 2 x USB3.0 and the usual audio ports. Theres even dust filters included throughout and a 35mm cable management compartment at the rear of the case to help with routing cables neatly.
To put it simply, I don't think there is a better case on the market for £55 or below. Phanteks have really knocked it out of the park with the P300 and we fully expect this to be an extremely popular case. Buy yours today!
Phanteks Eclipse P300 Glass Midi Tower Case - Black @ £54.95 inc VAT
With the highest build quality in its class featuring a full metal exterior and tempered glass side panel, the P300 is everything you need to build your perfect system.
Only £54.95 inc VAT.
ORDER NOW
