upgrade or over clock fx6300
next generation for Nvidia graphics cards. will be out 2018, but their not exactly in any pressure to release it sooner rather then later and can still milk pascal good :)
ah i see, maybe the way to go then i think. im assuming my 780ti wont play anything above 1080?
Im guessing its the Rev 1.0 you've linked and not any of the other versions?
I think if you have Rev 3.0 or 4.0 you'll be able to use FX- 9590 listed above for £160 - costly for an older power hungry chip- but if you havent got £400 for mobo-ram and cpu might be worth a shout
just found out its the rev3
will it be ok for over clocking? what CPU cooler would you suggest?
overclocking your current cpu? yeah will be fine ! was looking at your rev to see if you could install the FX 9590 cpu - if you could find a cheap one on ebay to install for some extra cores and speed.
havent used those chips so wouldn't want to spec to over or two under
but seems a good price and can mount across a lot of CPU sockets if your case can handle 240mm rad
https://www.overclockers.co.uk/id-c...-in-one-cpu-water-cooler-240mm-hs-008-id.html
im actually going to need a new case. so will need to be able to fit an ATX and this nice and cheap any recommendations?
was looking at this.. not overclockers but can't find much on here to match it price wise
CIT Dark Star Gaming Case at 26 quid
