Nobody thinks they're the bad guys.
It's ok to do these terrible things, because we're not the bad guys.
And if your entire mo-op leans on believing the 'others' to be the bad guys, then it's helpful to your cause when they do bad things. Escalation.
It's OK, it works and there have been no terrorist attacks since they started torturing people.
Provoke Muslims in the ME, watch a small minority retaliate, bomb the living daylights out of them, torture them, steal oil in the ME, make movies about it, profit.
This all started at the end of WW2 and America's problems with Iran. It's not even eye for an eye, it's eye for their eye.
They have had far, far less attacks, you meanIt's OK, it works and there have been no terrorist attacks since they started torturing people.
You're really going to need to provide some good evidence to show both a reduction in the number of terror attacks and to link that to torture etc rather than to, say, improved intelligence, policing and so on.They have had far, far less attacks, you mean
We're also not going to beat them by just torturing random folk because they happen to have brown skin and/or be called Ahmed.We are not going to beat these ***** by being all lovey dovey with them. If that means taking the gloves off and getting dirty then so be it.
You obviously havent seen the Isis torture videos, people being burned alive and having their heads slowly cut off.Well it should make you question who the bad guys really are.
Do you only see in extremes and nothing in-between?
Those that do inhumane things can't be reasoned with in "the normal way" therefore sometimes you have to fight fire with fire.
Except that every bit of proper research into such methods over the last few hundred years has said that information collected by torture (be it "no permanent physical damage" or "cut the fingers off, get out the hot pokers and electrodes" type) is effectively worthless.We are not going to beat these ***** by being all lovey dovey with them. If that means taking the gloves off and getting dirty then so be it.
I have actually, something that is forever etched in my mind.You obviously havent seen the Isis torture videos, people being burned alive and having their heads slowly cut off.
Ieds are designed to maim most commonly. So one bad guy who was most likely a terrorist drank a bit of water.
Hardly the same thing is it?
At least 120 people were tortured. Of those, at least 20% were so unlikely to be terrorists that they shouldn't even have been detained even under de facto martial law conditions. It's not known if any of the victims were terrorists, including any who confessed. People who are tortured often confess to things they're not guilty of, so often that obtaining false confessions is very often a large part of the point of torture.
Even if you don't give a damn about people being tortured (to death in one case), you should care about it making the situation worse. Once you start using torture, the least bad option from a political point of view is murdering all your victims and making sure nobody finds the remains. Otherwise, you're creating perfect conditions for more extremism. Even if you've broken your victims so badly that they're no longer functional, if anyone else sees them it will probably lead to more extremism. If you murder them all and nobody ever finds the remains, you're still creating good conditions for more extremism but not quite as good...unless the mass grave is discovered.
It's not the same thing, no. It's a lot more stupid. They want to create extremism, on both sides, because they know that it's politically useful for them. Barbarism on either side benefits them, not us.
A lesson their Frank and Goth ancestors learned the hard way from the Romans.By your logic guilty until proven innocent, and guilty by association.
The Germans used the same logic during ww2, one villager kills a German, retaliate , kill the whole village.
A fine soundbite but history has shown us they tend to prioritize defending the walls and not what the walls are defending."We sleep safely at night because rough men stand ready to defend the walls we sleep behind."
