- 23 Mar 2011
Like £10-15. I think they all do the same really just different names and models! Amazon have a fair few I just went for the one with the best reviewsPS2 to HDMI..? Is that expensive? I'm using composite still.
https://www.amazon.co.uk/gp/aw/d/B0...s=ps2+hdmi&dpPl=1&dpID=41D02Bfb4qL&ref=plSrch
It does stick out the back by like 2 inches once you have a cable in the end of it too. Not bad just have to have it brought forward on my desk a bit.
The way it's designed also means you can't stand it up vertically due to the usb cable that powers it sticks out the bottom.crap design in that sense!
This is one of the points for people giving it a negative review.
Also any reviews claiming it doesn't work tend to be from users not understanding the set up properly. Before you use it, with your current cables plugged in, go in to the settings and switch from RGB to the other mode in display settings! Can't remember what it is, starts with Y.
Then turn it off, plug the HDMI in and you are good to go
If you just plug it straight in without changing this setting first you just get a blank screen
I heard that the component signal doesn't support ps1 games so neither will this mod. So I haven't thrown the RGB scart out just in case I ever want to play ps1 on it
