Graphics card sugesstions £150 +
11 Oct 2016
Hi everyone
as you can see im after a upgrade in thr G card area and my rig struggles with the latest games , i run a i7 with 16 ram and i have a HD monitor but my rig struggles with the upper end games so advice for the best card under £200 that can cope ,ready to upgrade case as the H.P case has little room for a graphics card and thats the least of my troubles
thanks in advance
Could you answer the question please.
sorry for the delay
  • Form Factor: internal ATX
  • Total wattage: 460W
  • Nominal input voltage range:
    • 100-127V/3A (50-60Hz)
    • 200-240V/2A (50-60Hz)
    • Gforce GT 530
    • GPU Engine Specs
      CUDA Cores
      96
      Graphics Clock (MHz)
      700
      Processor Clock (MHz)
      1400
      Texture Fill Rate (billion/sec)
      11.2
      Memory Specs
      Memory Clock
      Up to 898MHz
      Standard Memory Config
      1 GB or 2GB DDR3
      Memory Interface
      DDR3
      Memory Interface Width
      128-bit
      Memory Bandwidth (GB/sec)
      28.8
      Feature Support
      OpenGL
      4.2
      Bus Support
      PCI-E 2.0 x16
      Supported Technologies
      DirectX 11, CUDA, PhysX
      Display Support
      Multi Monitor
      Yes
      Maximum Digital Resolution
      2560x1600
      Maximum VGA Resolution
      2048x1536
      Standard Display Connectors
      VGA
      HDMI
      DVI-I
      DP
I'd be surprised if it couldn't run a GTX 1060 at all. It's not like he wants to stick a Titan in there.
GT530 draws 50W
GTX1060 draws 120W.
Recommended PSU is 400W. If it was a 320W PSU I'd be a bit more worried
Its not that simple tallpaul as the gt530 is usaully a single slot card so need to make sure it can take a dual slot card.
Can you give us the model number of your pc so i can check the specs further Biggs, Motherboard and case.
Got the card you guys suggested thanks again but sadly it fits but not compatible with my motherboard so back to the start
