Are people's £ key broken?
Pound or pounds?
Isn't that one where both are correct, and neither are wrong?
Or maybe it is past tense or present tense?
My TV was two hundred pound?
That TV is two hundred pounds?
This is how I usually use pound vs pounds. Actually I don't know what is correct though.
£ key on a phone is usually in a weird obscure place, and on the iPhone it's a pain in the bottom to get to the front of a number, more so if you don't get it right first time would be my guess
It depends on the context. When it's a single pound, or describing a single item then it's pound, eg. "This costs one pound", "That is a seven pound item".
In that context the first line is wrong. Pounds should be plural.
So if I was to say
"One apple was two pound"
but if I was talking about three apples should it be
"These three apples were six pound"
or should it be
"These three apples were six pounds"
because it is not a single item?
Remove the s if it’s a single pound, but always have it if it’s any more than a pound (doesn't matter how many items).
“This shirt is one pound”
“These 5 shirts are one pound”
“This shirt is three pounds”
“These shirts are three pounds”
The exception being if it’s a single item and the item comes after the price
“that’s a thirty pound shirt”
That is unless your a London cabby or marketholder, then everything will be without the “s”.
“That’ll be for paund pleese”
:p
Technical is this correct, you say "that TV is two hundred pound", so the £ symbol should be after the number. You don't say "that TV is pound two hundred"
No it isn't, the way things are written doesn't necessarily have to reflect the way they are spoken.
