Stupid questions about i5 8400
I still don't think it's worth upgrading yet, since games arent really taking advantage of more than 4 cores yet. You've still got life in your 4770K, so I wouldn't bother upgrading yet. The money would make more of a difference going towards a new GPU or something
What is the 4770K overclocked to?
4C/8T at 4.4ghz+
to
6C/6T at 4ghz
All be it the latter does have an IPC benefit.
1. No, it's a locked CPU, only the ones ending in K are unlocked.
2. It's a locked CPU with 65W TDP, shouldn't be an issue with any Z370 motherboard.
3. Not really much of an upgrade, an 8700(K) would probably be more of an upgrade if you're really itching for one. But that 4770K should still be fine for 1-2 more generations even with a 1080Ti.
Don't you need something that is clocked really high for 1080p and high framerates? 7700K or 8600K overclocked.
I really don't know, but it would make sense what you say. I'm thinking of getting a noctua d15 for the 4770k to keep temps down and put more voltage to try and get it to 4.5 @ 1.3v my evo 212 = 85c in prime 95 v26. @ 1.27v
