I did post this originally under the PSU forum but there don't seem to be many takers nor is it as active as here. So, let me paste that message and see if you folk can help:
Hello all,
I currently have a Bequiet PurePower 530w model similar to this one http://www.bequiet.com/en/powersupply/43 except instead of 2x6+2 pin it is 2x6 pin. The specs are otherwise similar.
I was hoping to upgrade my AMD Radeon 5850 (2x 6 pin) to a Rx480 8GB AIB board (probably Sapphire Nitro+) but this requires an 8 pin plug.
I have seen 2x4 pin molex adaptors but don't think this is the way to go. The way I see it is I can only do this if I find an adaptor as in the heading (2x6 pin to 1 x 8 pin) but do they even exist? I think it is 2 male 6 pin to connect to the PSU and 1 male 8 pin to connect to the GPU. Perhaps the reverse. Will have to check.
On the very good assumption I do not wish to change the PSU, what are your suggestions? I may have to consider the GTX 1060 which isn't my first choice but certainly better then no upgrade.
530W is more than sufficient. My specs are i5 2500k, 1x5400 Samsung SATA 2 TB, 2x4GB DDR3, Radeon 5850 (currently), 3x92mm fans and 2x80mm fans with an SSD to be added and a couple of USB peripherals (dongle, KB and mouse)
Thanks
NB
Hello all,
Thanks
NB
