- 16 May 2007
That's good news, I know what you mean I am on the 9920 Beta BIOS for my motherboard which works very well
Yea I have just never built with AMD before so I had to get used to the way the UEFI was set up and how the multiplier worked.Using Manual voltage is what normally causes that 1.5ghz speed issue..annoying as hell. Should have been fixed long ago.
Obviously you can't just type 39 and expect it to go to 3.9GHz, you have to increase the FID until it displays your target clock speed in the top corner. I'd gotten tired and frustrated and didn't realize that entering 39 in FID was leaving me with a clock speed of about 800MHz and the correct value to enter was something like 152 iirc.
Yea it's a bit odd that they've done it like that when the whole purpose of it is to achieve a target frequency anyway.I feel bad that on my board I just type the target frequency...
