shipping puts it just over the £2k mark, but if you lower the 500gb sdd back to its originally spec 250gb then its £39 saving allows you to buy a usb dvd drive to install the windows, that or keep it as it is and just remove the windows option then buy the usb install version separate.
it comes selected with a 1070, but the budget allowed the 1080ti option as it did with the upping to 7700k, its £160 to add 32gb ram option should you need it, so a raised budget or a downgrade somewhere to fit it in.
My basket at Overclockers UK:
- 1 x Titan Virtual Force VR Gaming PC - Intel Core i5 6600K @ 4.5GHz, Nvidia GeForce GTX 1070 8GB Graphic = £1,987.98
- Graphics Card:Asus GeForce GTX 1080Ti ROG Strix OC 11264MB GDDR5X PCI-Express Graphics Card
- Primary Drive:Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)
- Secondary Drive:Seagate BarraCuda 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM006)
- Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
- LED Lighting
hanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO)
- Case
hanteks Eclipse P400 Midi Tower Case - Gun Metal Window
- Virtual Reality Headset:Unwanted
- Processor:Intel Core i7-7700K 4.2GHz (Kaby Lake) Socket LGA1151 Processor - Retail
- Memory:Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Black (CMK16GX4M2A24
Total: £2,002.08
(includes shipping: £14.10)
or theres this coffee lake system, again shipping puts it over budget, however there is an Aorus 8gb 580 version for £30 less, wont be as strong as the 1080ti either way, but intel meant to be stronger performers, this is pre-config spec, i didnt alter anything.
- 1 x OcUK Gaming Neon Overclocked Gaming PC - Intel Core i7 8700K @ 4.9GHz = £1,999.99
- Case:In-Win 805 Aluminium Midi-Tower Case - Black
- Memory:Team Group Night Hawk RGB 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - RGB Black (TF1D4
- Solid State Drive (Primary):Samsung 960 EVO Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
- Solid State Drive (Secondary):Unwanted
- Storage Drive:Seagate BarraCuda 3TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST3000DM008 )
- Security Software:Bullguard Anti-Virus 2017 - 1 PC 1 Year **Offer Price**
- Graphics
owerColor Radeon RX 580 Red Devil 8192MB GDDR5 PCI-Express Graphics Card
Total: £2,014.09
then you got these from AMD side, i chose the 1800x option as it comes with a free nitro chair which might not be needed, but they are expensive seats, so its a bonus or only £69 on top, this build allowed for 32gb ram to be added, also its a vega 64 only for the graphics, this pack also comes with couple cool games aswell.
- 1 x Radbox Pro AMD VR Ready Gaming PC - AMD Ryzen 7 1700X, Radeon Vega 64 8GB = £1,947.98
- Case:In-Win 101 Midi-Tower Case - White Window
- Graphics:Sapphire Radeon RX VEGA 64 8GB HBM2 PCI-Express Graphics Card - Stand Alone
- Memory:Team Group Vulcan T-Force 32GB (2x16GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD432G2
- CPU:AMD Ryzen 7 1800X WIth Free Nitro Concepts Gaming Chair
- Primary Solid State Drive:Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU)
- Secondary Solid State Drive:Unwanted
- Storage Drive:Seagate BarraCuda 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM006)
- Sound Card:Unwanted
- WIFI:Unwanted
Total: £1,962.08
this one also has 32gb ram option, i wouldve chose the 2nd gpu for the sli option, but they are all well over double what the add on cost for the single 1080 which i chose as it is better than the pre-selected 1070, i didnt bother with choosing 1700x or 1800x that both come with the free chair this time(+ £51 for the 1700x ), but if you ever did want to go SLI this system is packed with an 850w power supply so your good to go, this build also allowed a 500gb ssd to be added and staying in budget,
- 1 x Titan Nodachi Overclocked SLI Pro Gaming PC - AMD Ryzen 1700 @ 3.80GHz = £1,977.98
- Case
hanteks Enthoo Luxe Glass Midi Tower Case - Gun Metal
- CPU:AMD Ryzen 7 Eight Core 1700 3.70GHz (Socket AM4) Processor - Retail
- Primary Solid State Drive / Hard Drive:Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)
- Secondary Solid State Drive / Hard Drive:Unwanted
- Storage Mechanical Hard Drive:Seagate BarraCuda 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM006)
- Optical Drive **Please Check Case Support**:Unwanted
- Lighting:Unwanted
- Operating System:Unwanted
- Build Time:Standard Build Systems - Dispatched within 7 working days
- Security Software:Unwanted
- Graphics card:Asus GeForce GTX 1080 Turbo 8192MB GDDR5X PCI-Express Graphics Card
- Graphics card 2 (SLI):Unwanted
Total: £1,992.08
