Hi all,
My recent eBay purchase has developed a fault this week. It's a Mk2 Mondeo 2.5 V6.
The car was fine for the first few weeks but now struggles to start after being stood for a while (i.e. overnight).
The engine turns over on the starter but won't fire. I can get it to start by pressing the throttle a bit, it coughs for a few seconds and then is fine.
I think the starter and battery are strong.
I am thinking perhaps a leaking injector. I don't get any smell of petrol when it struggles to start though.
If the car has only been stood for a few hours it starts perfectly, every time.
Am I right in thinking that if I pull the fuel pump fuse later tonight making the car cut out from fuel starvation that will mean that there is no fuel to leak through the injector? So, in theory it would start on the turn of the key in the morning?
I have never worked on a car's fuelling system and only am thinking leaking injector from a few things I've read online. If it proves to be a leaking injector then what's the fix?
Worth mentioning I broke some vacuum pipes recently and replaced with some hosing from eBay, I believe the vacuum is for the cabin heater and EGR though. I also cleaned out the idle air control valve to cure the moosing problem common on this engine.
Thanks again guys.
Thanks again guys.
