I just want to run this past GD to see if anyone has used a better solution.
After years of shoving them all over the house I need a proper display solution for my antique swords. The plan is to buy an Ikea bookshelf, remove the shelves and use magnetic hooks to hang swords inside, from the rear panel. This rear panel is wooden and 3mm thick. To retain the hooks and the weight of the swords (just under 1kg each, on average) I'm thinking that I can then buy magnets for the other side of the panel - but I don't understand all the magnety technical stuff and am only assuming this will be strong enough.
Has anyone used magnets for something similar and were they strong enough?
(This thread might have been better in Home but I'd like a wider range of responses.)
