Upgrade recommendations for my current PC?
24 Sep 2017
Looking at upgrading parts, possibly whole system what do you guys reckon would be best? budget around 1500-2000
CPU
Intel Core i5 4690K @ 3.50GHz
RAM
8.00GB Dual-Channel DDR3 @ 666MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co. Ltd. Z97X-SLI-CF (SOCKET 0)
Graphics
2047MB NVIDIA GeForce GTX 760 (ZOTAC International)
Storage
931GB Seagate ST1000DM 003-1CH162 SCSI Disk Device
CPU
RAM
Motherboard
Graphics
Storage
What Res do you game at ?
Drop in a second hand i7 4790k Nd overclock if, maybe with an AIO
And a GTX 1070/80 or Vega 56
If you haven't got a gaming Sync monitor, no maybe the perfect time to grab one .
Just trying to guage if you went full upgrade route - using your case and storage, may be able to list PSU but you've not stated it , and just included a screen as in case
My basket at Overclockers UK:
Total: £1,499.04
(includes shipping: £14.10)
But as above, give thought to getting i7 4790k
Pretty much what orbitalwalsh said, a monitor with sync to your graphics card is a great addition and something you notice when playing. What storage you got, ssd?
Storage is jsutr a hard drive lmao, power supply is a corsair 750w, im thinking of just upgrading the whole system and replacing it, then this can be a daily driver.
You need to get an SSD, it’s the damn law! It’s one of the best things you can do to make an upgrade worthwhile if you are on a bog standard hd upgrading to an ssd is immense
If the above Ryzen with screen doesn't quite float your boat for part upgrade and you want to keep your old system
Total: £2,003.50
(includes shipping: £14.70)
Water kit to keep you entertained whilst building
Total: £2,003.50
I think im just gonna replace the whole system tbh. ty for the rec
Nothing much up with that CPU. I would first upgrade the graphics card. With a 1070 for example you will notice a massive difference playing games. Ditch the SCSI and get two new drives, an 256GB SSD for the OS and 1tb SATA or more for work data and games and so on. You will notice a massive difference in speed with the SSD, and you might as well get a modern 1TB+ drive because they will be faster and cheaper. As someone said, since you need a new graphics card, may be the time to invest in a good sync monitor. But, anyway, right now the CPU is the strongest component so I wouldn't replace that just yet.
