Hi all,
I want to upgrade to 1440p for gaming (low/mid settings fine) and hit 60fps.
relevant PC specs
i7-2700k (4.4 GHz)
GTX 1060 6GB
16 GB RAM (DDR3-1800)
As part of a case upgrade I am getting a 240mm watercooling AIO for the CPU, so that should OC to 4.7 GHz (it is stable but too hot right now).
Problem: I JUST bought the 1060 and am already concerned it will struggle at 1440p. I also run two screens so I can browse/watch videos at the same time, so it is potentiall 1440p gaming + 1080p youtube videos. The setup is fine at 1080p+1080p right now.
Will this be okay or should I try to swap it for a 1070? Or is there a risk my old CPU will bottleneck things?
Can't afford a CPU/mobo upgrade right now and not convinced it is cost effective anyway.
Thanks for any help
Mike
relevant PC specs
i7-2700k (4.4 GHz)
GTX 1060 6GB
Thanks for any help
Mike
