Hi
Thank you for the reply's and sorry didn't give you much info.
The Pc is going to be mainly for gaming and just other normal day to day stuff ie browsing,email etc.
If possible i would like something that is going to last a few years as not one to keep upgrading every year.
Storage wise i was hoping at least a 250g ssd(more if possible) and a 1tb HDD.
No preferred vendor .
Screen size would be 27inch if possible.
As to resolution well not sure to be honest.Would you be able to let me know pros and cons between going 1080p or 1440p ?
Basically not as clued up as you guys on this and dont want to spend my money and end up with a crock of ** Fully Star out swearing **.
Thanks again and i hope this is the info you need.
intel i5 8400 is better for gaming in most of the cases- and should last a while but as in terms of upgrading, its a closed system unless you grab a i7 K version in the near future.
AMD have confirmed 3 generations on chips on the AM4 socket, so current boards will accept newer CPU's down the line - mean in 5 years time you could pick up a 3rd Gen Ryzen chip. AMD given no clue about them but might increase core count but speed should be up!
I spec's the systems with SSD/HDD combo to make life easier , top one having double the spaceTrying to find a 27" monitor with Freesync proved a bit tricky, can get monitors that size without and would be cheaper.
worth doing some research on freesync- Gsync to see why its a good thing to have if you can budget it in
Sorry I wasn't the OPI was just recommending a 27" Freesync after you had mentioned they were tricky to come by.
Thanks again for the advice and yes i will be self building.
