Gigabyte "Check Number"
27 Apr 2004
Andover
@GIGA-Man
Hey Giga-man,
Is there anyway to get a Gigabyte mobo and gpu check number if you dont have the boxes?
I bought a system with gigabyte products so I have the serial and EAN numbers, but in order to register the hardware with gigabyte support you need a check number which I dont have.
I have contacted support under ticket / email-id 458950-1 and 458950-2 but they haven't been overly helpful :(
Cheers,
S
I will try and find out for you.. will get back ASAP and let you know how to find it. In the mean time, what's the issue with the motherboard? If you let me know the problem in detail I can try and help.
No issues fortunately mate. I just want to register it for the steam voucher :)
Thanks for the reply dude!
Let me see what I can do for you, it may not qualify. Based on where we are, I would always recommend you buy an OCUK system ;-)
Thanks Giga I really appreciate it. I dont see the difference personally as they would have taken the mobo out the box with the check number on.... difference is it was pre-assembled but the cash I paid still funded the mobo/gfx. Anyway, either way, what will be, will be :)
In regards to the system, I am gutted OCUK had no i8700k stock otherwise I absolutely would have done. It came down to timing with a week off work and wanting a new system to game on!
Resellers buy true trade, had many Asus from ***** were I couldn't get the codes - think only if it was Intel or amd directly did I get them
Some to see someone's going to check though :)
Makes that purchase just a bit sweeter :D
Hello icehot,
I am really sorry but the only place you can get the check number is on the box... I will ask if we can process your request with out it. Do you have a copy of your invoice with the board listed on it?
Hello icehot,
No worries mate and thanks for following up. Do you have an email I can send it to?
