My GH last night was having another dumb moment. Ask it a simple question and it 'doesn't know how to do that'. Quite annoying having to ask it to switch on the lights and it has a dumb moment!
Whilst I have no doubts of their AI capacity and googles long term prospects, it irks me somewhat that the Home has only two mics, which makes picking up speech difficult in a noisy room or like me, having the home near the TV and having it rarely pickup either mine or my wifes voices correctly. Whereas a friends Echo Tower thing can pick up voices even in the middle of a small party.Frustrating for sure but help is on the way. I somehow think that you and I both know this problem can be solved and Google Home will just keep getting better. Remember, AI and deep learning is now in their DNA and GH and Google Assistant are key to them to spread this feature. So why am I so confident?
Okay... <snip> all my speakers are playing perfectly in time!
Okay... so I only just learnt about setting up a group. (I don't really listen to music using the Google Home, so I've never really looked). If you're a bit thick like me though, go into Google Home, Devices and then tap the menu three dots in the top right of a device card and you can create a group and add all/some of your devices to it. Now I can say "Hey Google, play {insert music here} to {insert group name}" and all my speakers are playing perfectly in time!
My TV's got a built in Chromecast, so it's the name of the TV, which is also an android smart TV.
I can get it to do it to the chromecast upstairs, but not the chromecast on my TV, as it tries to do it via android tv.
I'll give this a shotNot sure if you fixed this, but you need to go to Settings > About and rename the TV to one of the preset names like 'Living Room' or 'Media Room'. Had the same problem on my Sony TV.
Does this change the name of the chromecast or the TV?
ErmNew Google Home Mini gets 5 Star rating from The Guardian:
https://www.theguardian.com/technology/2017/oct/26/google-home-mini-review-voice-assistant-speaker
Oh no! Does that mean it won't work on my Google Apps email -- I don't know what Google call it nowadays but it's my domain name email address run by Google Apps.
- There’s still no support for G Suite accounts, only personal Google accounts
This works great thanks.I think this changes the name of the TV, the chromecast just copies the TV name.
