- 19 Oct 2006
Have you tried to clean install Office?
Office 2007 is now end of support (although I have seen it work without issue on Win 10 1709).
How do you know if your getting the fall update if you install via usb media creator?
Apologies, i meant before you install?In System it will tell you the version of Win10 installed ie Fall edition update is version 1709.
Right click the .exe you downloaded>Properties and check the details tab for the version number. It should be 16299.15. If you've already downloaded the ISO then you can mount it and check the version of setup.exe in the same way.
I have just checked for updates today and still no fall update?. But do I want it though?
Will do, plus I have changed this to "Current Branch for Business" so hopefully it wont be appearing anytime soon.I would wait it out to many issues it has been rushed out again.
