Hi all,
I'm in desperate need of a processing upgrade, as my spec suggests:
Intel i5-760
16GB DDR3
AMD R9 280X
I've just today sourced an i5 6600k from the MM, so I'm in need of a Socket 1151 motherboard and DDR4. My current plan is to source the RAM from the MM as well, but I know nothing about motherboards. A quick look on the OcUK website and it seems there are numerous chipsets available for Socket 1151.
Setting a mid-range budget of approximately £70, what chipset should I be looking at for this CPU, and what should I be aware of in doing so? I'm aware that my GPU will be obsolete in the next year or two, but my reasoning is the 6600k and 16GB of DDR4 should keep me going for another 3 years.
Any advice appreciated!
Intel i5-760
16GB DDR3
AMD R9 280X
