Hey guys. I had the clutch replaced and a new gearbox casing on a v.w passat 2l 2012 4 months ago at the main dealer. No one else has been near the engine.
Today, the car lost all its coolant through a hole in the pipeline. Looking under the hood we can see the engine shaking so bad that the cambelt has been grinding against said hose, also the radiator fan has worn a hole into the turbo inlet hose. This is clearly an engine mount failure, hence the engine moving around so much causing parts to hit other parts.
So, do you think the volkswagen dealership failed to put the engine mount in properly when dropping and repairing the clutch and gearbox, causing it to fail and damage the parts said above?? I'm slightly amazed a 5 year old cars engine mounts could fail.
