Homebuyer Report.....Help with Issues
7 Nov 2006
Stockton on Tees
Okay
So I've had my home buyer report back and there are a few issues highlighted...
Score of 2 (serious but not dangerous):
...The cement pointing at the side of the valley gutters needs to be replaced in some areas.
...As with the main roof the side of the valley gutters needs to be replaced in some areas.
...The external joinery includes fascias, soffits and bargeboards and these are made of
timber. These need repainting now.
Score of 3 (Serious!):
Electrical Consumer Unit:
There is a mains electricity supply and the consumer unit is located in the former garage.
The electricity supply was on when I inspected. To meet current standards the consumer
unit should be manufactured from noncombustible material (usually metal), or be enclosed
in a cabinet or enclosure constructed of noncombustible materials. In addition the
electrical system is not covered by a current inspection and testing certificate.
Gas Supply:
There is a mains gas supply and the meter and control valve are located externally. The
gas supply system is not covered by a current inspection and test.
The gas appliances, including any gas boilers, gas heaters, gas fires, gas cooker, and gas
hobs should be safety checked and serviced once a year according to the manufacturer's
instructions.
Boiler:
The property is heated by a wall mounted gas boiler located in the Kitchen There is no
evidence that the heating system has been checked or serviced within the last 12 months.
This is a safety hazard. This should be resolved now. Heating systems and appliances that
have not been checked may be a safety hazard.
Should I be asking the vendors to resolve these issues or have money knocked off?
Any advice would be greatly appreciated.
Thanks in advance.
Just sounds like the usual stuff to me , trying to justify the cost of the second gear survey and avoid the possibility of being sued .
Edited to add have you been offered the mortgage yet?
You should do which you think will get a result but how much do you think it going to cost to rectify ?
Dont know is the simple answer.
I guess i'm looking at:
- Boiler inspection cost
- Gas inspection cost
- New consumer unit
- Cement pointing on drains
- Some guttering to be replaced..
The boiler for instance is not a safety hazard , there exists the remote possibility it is, but that could occur whether it has been serviced or not.
Totally depends on the house. If you've offered top money for what was advertised as a tip top house then yea insist they are done. If you have bought something that needs some work and tidying up and you've agreed a price with that in mind I'd just consider it as part of the deal.
The roof is a day or a couple of days for a roofer to lift the tiles and repoint. The danger you run is if you insist the seller does it they very well could get someone just to 'butter' them up which won't last long.
The gas and electric just isn't up to today's standards. What house is? Again consider what you think you've bought.
Electric can be a big problem. Fit a new consumer unit with modem breakers and it could just push any problem down the line whereby you need a complete rewire.
- New consumer unit
mate think about it, he's having a laugh.
By the way when you buy a house you will have to spend money maintaining it, how old is the boiler for example.
When viewing houses I always check the condition of the electrics and gas, age, service history etc
An old boiler or re-wire wouldn't necessarily put me off a house. I'd just factor it into the price I paid.
I know I will run in to problems with the consumer unit because I plan on having loads of spot lights fitted when I move in as well as other minor electrical stuff. The electrician could insist that the consumer unit be renewed before work is carried out...
Boiler is from 2000 when the house was built
blimey, the house will be fine, the boiler is probably a bit past its sell by date, but if its working its fine, get it serviced when you move in if you're worried, but it won't cost much, the same for gas fires.
I seriously doubt a consumer unit fitted in 2000 has any problems what so ever.
I was looking at getting the boiler replaced in a year or two after I move in anyway. I would want the latest energy efficient one. Think that's to be expected.
But should i insist on the vendors getting it serviced anyway?
seriously, only if you get succer tattooed to your forehead.
The consumer unit has to supply an oven and maybe electric shower, a load more than a few spot lights.
I bought a new house in in 1992 and I consider that modern.
The house I currently own was built in the 70s and I have spent money on a new consumer unit and boiler. It had a baxi boiler and fuse wire.
What I meant was would an electrician still do new work in a property even if the consumer unit is not to current regs? Would he still sign off on it?
I'm going through the process now...valuation has been instructed
yeah as I said the surveyor is just covering his arse, see what the mortgage company say.
The trouble with reports like yours is I doubt he went into the loft or looked under any carpets.
Mind you as I said a house built in 2k will be fine unless something has gone very wrong.
Does it have upvc windows? I expect so, what state are they in? Is the roof insulation up to spec, if not you might be able to have it done for free.
What's the bath room and kitchen like? Any built in appliances, they might need replacing.
Yes, UPVC windows
The whole house was renovated in 2016 with a new kitchen, bathroom and en-suite. New carpets and flooring too through out the house.
Kitchen has built in fridge and dishwasher both 2 yrs old now.
