- 10 Feb 2011
Does using DSR change the scaling on the screen or does it fit right on any screen and any DSR resolution setting?.
With AA turned off i can have it at maxed with out performance hit at 3840x2160 X3 DSR and at the moment got it set to 33% in the NVidia control panel. Everything does look fine and a lot better then using AA. I was wondering if using DSR in different resolutions could make the scaling off and make things look bigger or squashed etc?.
