Cooling for new build
9 May 2012
South Wales
Good evening guys
Im just seeing what everyone opinion was on the cooler master, masterliquid lite 240 for the ryzen range ?
has anyone used this and give there opinions as ive read a few reviews
also can someone glarify how best to install cause ive heard cases off people doing fans different positione i.e above or below the rad, which way is best ?
its going to be going on the rog strix b350-f gaming board with Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit - Black/ and soon ryzen 5 1600 cpu
cheers mark
Cannot comment on coolmaster stuff myself. TBH the 2 main AIO leaders are corsair or NZXT. Having fans in push or pull doesn't really make a big difference. I personally use in push configuration as my LED fan lights are obstructed.
Have the radiator top mounted as heat rises so its the quickest way to get heat out of the case. Having it front mounted will restrict air flow and just pump more heat onto cpu/gpu
thanks
