PC dead this morning - presumably PSU?
29 Apr 2015
Asus Z170-E
Intel i5-6400 (non-K) @ 4.4Ghz
Kingston Fury Black 8GB (2x4GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Black (HX426C15FBK2/8)
Alpenfohn - Brocken 2
NZXT S340
Corsair CX600M
2 x Samsung 840 Evo 250GB
Geforce GTX 960 4GB GDDR5 OC
Getting a flicker of power but overall nothing. Have disconnected my 1070 and PC seems to spring into life.
So is PSU dead? Is it underpowered?
You got two graphics cards there or what?
Short circuiting graphics card would trigger protections that way.
Or failed card messing with motherboard could cause it to "crash motherboard" stopping boot process.
For single such card 600 watts isn't underpowered, more like the opposite.
But despite of what brand name might suggest that PSU is standard mediocre quality one with cheap C(r)apXon capacitors.
So would anyway put that to replace in few years category if it gets lots of running hours daily.
No, just the one card. Yeah Going to go pick something up shortly.
GTX 1070 is indeed more power hungrier than GTX960 but difference shouldn't be that high during boot...
And if that difference would be enough PSU would be anyway ready to release "magic smoke".
New PSU installed yesterday, tested ok.
Put 1070 back in... it's toast :(
