A lot of problems can be solved with trial and error. But that requires being brave enough to play (hardware and software)
My desktop wouldn't even power up yesterday (no power to motherboard at all).
Took power cable out, ram etc, put back in and worked. Probably a problem but fixed just being confident enough to use general problem solving.
If it had been broken I would have scrapped the lot. Just not needed anymore a PC for 95pc of people. And a lot who use one use an encapsulated solution (tablet, laptop) anyway.
Unless you're a hard core gamer or need special cpu/gpu requirements a desktop isn't needed. And if you do, you probably know about PCs internally and software anyw!
