Trickle vents open in the windows 24/7 (throughout the house), we use the downstairs bathroom mostly (which is vented to outside), and the kitchen is well away from the bedrooms (and also vented). We have a gas fire, although it hasn't been on for ages and it isn't flueless.
"You want to try to avoid too much airflow in that area " - interesting. Given that the window doesn't seal properly, there is a draft all around it. Could this be making the problem worse?
I think I'll see how I get on with the dehumidifier and leaving the kids door open overnight. Failing that, the window does need replaced.
Our house was built about 1925 and either has no cavities, or they are incredibly small
Yes it works well and relatively easy to install. I didn't do the wiring however as said previous its effectively a fused spur off lighting socket.Does it work well, easy to install? What did you wire it up to?
I've looked at these in the past. But I should first start by installing extractor fans in my bathroom and kitchen, as at the moment we have to open the windows, and in the winter months, it is freezing!
I fit Mechanical Ventilation & Heat Recovery Units and Positive Input Ventilation Units as part of my job as an electrician.
A lot of houses have poor ventilation, this is due to the retrofitting of cavity wall and loft insulation, so damp air is struggling to escape the house due to them becoming more air tight.
As the damp air cools it find the coldest spot, the windows, and clings to it. Window trickle vents aren't going to do enough. If you actually do the calculations for how many people are in the house, how much moisture is being produced and how much the trickle vents can move then you'll find them woefully inadequate.
My recommendation would be to install a PIV unit. These things take the air from your loft and filter it, some have comfort heaters too, then they blow this around the house. You will find that a PIV will all but eliminate condensation problems by keeping a constant supply of clean dry air moving around the house.
PIV units start from about £300 for a Nuaire unit and the Enviro-Vent and Vent Axia units can go past £500 for the higher spec ones.
If you are comfortable with fitting a fused spur in your loft taken from a lighting circuit then it is something you can install yourself to save the cost of having a specialist do it. It would take little over an hour to get done, the hardest part is cutting a large hole in the ceiling for the ducting.
I'm in the North West sorry. If you contact Enviro-Vent they will put you in touch with a qualified installer.We are about to have a PIV system fitted, 60s detached bungalow with all the trappings to make it condensation hell - double glazed, cavity & loft insulation with 3 of the 4 fireplaces blocked off!
What is the difference between envirovent and nuaire in your experience, money to a degree is not an issue as just want a long term solution?
Do you recommend the heat versions, is it ok to insulate around them?
Don’t suppose you work on Norfolk area, struggling to find installers with knowledge of the products!?
