I have had this Radeon 6850 since probably 2010 so it's getting on a bit in tech terms. I does ok for what I need. No heavy gaming just World Of Warcraft which it will run on max although not perfectly but playable non the less.
I now need to replace it with something newer as the fans are making a racket and I don't want to faff about changing them. I don't need anything particularly powerful, WoW on full settings and a smooth frame rate would do the job. As long as it is more powerful than the 6850 it will be fine.
Having been out of the loop for some time I am not sure what is about, at what level all these cards are and how much/little I need to spend to get the required result so any suggestions would be most welcome. Also interested in anything that might be good value on the used market.
. At the moment I would guess it's the graphics card that is holding back the cpu
