Hi, I recently spilt about 500ml of juice over my much loved Macbook Pro Retina HD 13"and fried pretty much everything inside of it.
So after some research I think it fits my needs more, and it should save me some money to build a PC? Also in the future it will be more customisable, more so than the macbook pro.
I'm not looking to build the most expensive set up as i am quite cash strapped. Would be looking to spend about £500 at most, but would build on this in future.
My needs for gaming are mainly older style less demanding games, I do play CS:GO occasionally so it would need to be able to run this, 40-50fps is more than enough on med/mid settings and wouldnt mind being able to do some video editing as well.
I currently have 2 turntables with serato as well but this only requires USB 2.0, 2 GB memory and at least Intel 2.0 GHz Core Duo.
I also stream films, netflix etc to a HD 1080p tv so don't require 4k streaming or any of that but would need a HDMI output and would be looking to get an SSD for sure, 120gb would be ample to begin, but would probably look to upgrade to more within 3 months.
I was looking at another website that said a good start up PC suggestion was this, what do you guys think about it?
Ideal
GeForce GTx 1050-TI Graphics Card £140
AMD Ryzen 3 1300X AM4 CPU £110
Gammax 400 Heat sink & Fan £25
MSI B350 PC Mate Motherboard £80
8GB DDR4 Corsair 2400mHz Ram £79
PNY CS1311 2.5 in 120 GB SSD £65
EVGA 500B power supply £57
NZXT S340 PC Tower £68
Total £624
Or cheaper alternative
GeForce NVIDIA GT 1030 £63
Intel Pentium 3.6ghz G4600 £77
STOCK £0
Gigabyte B250M-DS3H £60
4GB DDR4 Corsair RAM £36
PNY CS1311 2.5" 120GB SSD £65
Total £426
This ideal set up is still over my price range so the cheaper alternative is to take the cost down, am i sacrificing a lot of performance and adaptability by doing this?
Also what about the DVD player, sound card (does this have aux ports?), WiFi and USB, are these all bought seperately are they all compatible?
As for Operating system, I'm reluctanct to pay £120 for windows 10, If running a windows OS system I would rather Win7 but im open to advice, I currently have a Keyboard & mouse so this will not be required, also im not looking to budget in for a monitor/screen here either as i can use my home HD tv in the mean time.
As you can see this is all quite new to me and some suggestions and help/advice would be greatly appreciated
Thanks, Daniel
Ideal
Total £624
STOCK £0
Total £426
Thanks, Daniel
