We are currently in the process of renovating our conservatory after fixing a leak at the start of the year. We have had everything replastered and are now in the process of sorting out the floor which has sunken in one corner, due to I assume the leak warping the chipboard subfloor.
We were considering getting Karndean laid in the conservatory and have had three people round to quote for the work.
Two of the people who came over (one who was unable to see the subfloor as I hadn't lifted the old floor at the time), quoted for the work without issue.
The third person who came over has listed out a number of issues and I am unsure how serious the issues are or if he is just trying to increase the size of the job.
The issues he has indicated are:
1) At the moment the joists are 60cm apart (based on the screws visible on the chipboard). The third person thought that actually the joists should be 40cm apart. At 60cm apart we are running the risk of the floor being uneven and 'wavy'.
2) Chipboard is an unsuitable material for the subfloor and should be completely replaced with plywood.
3) Karndean isn't suitable for a conservatory and that as the heat gets to it it'll contract/expand and cause issues with gaps appearing in the floor.
It feels like the third guy might just be trying to make it a bigger job for himself (although having spoken to him on the phone he says he wouldn't normally do the joist stuff himself and would get a builder to do it).
