- 4 Oct 2017
For what it's worth in my own experience, coil whine happens on most graphics cards depending what's happening. An unlocked frame rate on a menu screen for example where a gpu might hit 200fps will generally cause serious coil whine on the majority of graphics cards.
With a lot of cards now where the fan remains idle until it hits a certain temperature it can make any coil whine more noticeable. I'm quite ocd and if I open the side panel and put my ear up to the card I can normally make it out. The issue's are the cards that have coil whine so bad you can hear it from normal usage.
In "normal" usage, there is definitely variance between even multiple units of the same card, let alone different manufacturers. So it's often worth going through an exchange.
My own solution to anything like that, which might not be considered a fault as such is to buy from a retailer with a good returns policy so you have peace of mind and can return the unit hassle free.
Ultimately I find trying to gauge noise online is quite difficult due to the amount of variance, people have different environments, seating positions, hearing, and more importantly tolerance levels, so someone on a forum saying their card is noisy or quiet often doesn't mean much. The most important thing is the user themselves, if it's unacceptable send it back
I remember being annoyed with the noise of my reference 980ti and a work colleague telling me their's was really quiet on full load, yet when I seen it for myself it was arguably noisier than mine lol. Perception and tolerance makes a big difference.
