Critique my basket
18 Oct 2002
Pembrokeshire
Planning an internal upgrade and have this lot in my basket.
Any comments or glaring mistakes?
Can't help but feel you're over-spending on that bundle. You could buy that CPU, a decent motherboard and have your choice of coolers and save a fair amount - enough to drop the 1070ti in favour of a 1080 and get 3000mhz RAM.
Thank you for replies.
Think I'll go with that basket Southernorth. I have a hydro cooler which should fit the CPU so can knock off the cooler :)
This RAM is also worth considering:
My basket at Overclockers UK:
Total: £197.58 (includes shipping: £8.70)
The GTX 1080 for £439 isn't on OCuk, but I'm sure you can find it quite easily.
There are also some very well priced Ryzen 7 1700 bundles at the moment, if you were intending to do more heavy multi-tasking than pure gaming.
