TL;DR... I'd like to build a system for £1000-1500 depending on how much I spend on a monitor. Am I wasting a ton of money going for the LG 38" 1600p (£899) when the 32" AOC 1440p can be had at £199 right now? Total budget is £2000 +/- £100. Need a mechanical keyboard and mouse as well.
Good morning folks. Your input and advice would be much appreciated. I've a venerable old i5-650 that I put a new PSU, GTX750 and SSD in last year, but I'm not sure if I'm up to the challenge of a full build from scratch...is it that hard? So I've been looking at the OC Black Friday deals for pre-built systems, but I'm willing to take on the challenge for a build.
I've been looking at this and it appeals, although I'd not choose that case personally and I think the processor is an older generation? Comes with a free keyboard and mouse bundle (although I'm sure you're paying for it in the price of the deal somehow - nothing's ever 'free'
https://www.overclockers.co.uk/radiance-gamer-asus-aura-sync-rgb-gaming-pc-fs-1am-og.html
This is a bit more. I know little about AMD but appears to be one of their higher end chips.
https://www.overclockers.co.uk/ocuk...ming-pc-amd-ryzen-1800x-8-core-fs-1c2-og.html
Basically the starting point is either the AOC 32" monitor or LG 38" linked below, I know there is a massive price difference and the 38" will eat into the budget. If I go super wide it needs to be an LG because of Sony PS3 (playing GT5 and GT6) display integration.
https://www.overclockers.co.uk/aoc-...reesync-widescreen-led-monitor-mo-04g-ao.html
https://www.overclockers.co.uk/lg-3...-super-wide-curved-led-monitor-mo-149-lg.html
The motherboard needs to have SPDIF out for audio, or I guess a soundcard with that facility could be included in the build. Sound goes out to an AV Receiver, would I be better having dedicated sound? Support for SLI would be nice for future upgrading too.
I'd like a midi case, something quiet, discrete and simple in metal, with 5.25" bays behind a panel as I'll be putting an optical drive in. I'm not bothered about lighting but if the motherboard supports it then great. The Fractal R4 and Coolermaster Silencio 352/452 appeal. I know there are some lovely aluminium cases out there and buying an external DVD-RW isn't out of the question.
Will I warrant a 1070 card? What about cooling? Do I really need liquid cooled?
I hope that's enough to go on so far. I'll check back to the thread regularly to answer any questions.
In terms of games I play on the current computer - Civilization 6 (slowly lol), Diablo 3. I'd like to be able to play Player Unknown Battlegrounds, Assetto Corsa and other similar games on this new machine. I guess I'll need a 1060 at the minimum but 1070 would be nice.
Thank you in advance for your advice!
).https://www.overclockers.co.uk/radiance-gamer-asus-aura-sync-rgb-gaming-pc-fs-1am-og.html
). I've asked the OC folks to price up the build, I can always drop the LG monitor off the list anyway and replace it with the AOC (it won't affect the build labour time in any way), so £2.2k suddenly becomes £1.5k.
