Who wins the silicon lottery?
In this thread we can get a normalized comparison of GPU quality between different 1080 Ti cards by posting here your max stable core clock @ constant 1000mV 60C.
How to do it:
1) Apply defaults @ Afterburner and set -200MHz to Core Clock, hit Apply.
2) Press Ctrl+F to open the Voltage/Frequency curve.
3) Click on the 1000mV dot and drag it to around 1900MHz, hit Apply in the main AB window, this will lock the voltage to 1000mV under load.
4) Make sure your GPU temp is below 60C before the next step.
5) Start Unigine Heaven Benchmark Extreme preset in windowed mode, keep it looping while adjusting fans so that Core temp stays near 60C.
6) Keep dragging the 1000mV dot up and hitting apply until the benchmark freezes. Often Heaven simply closes itself on crash, if not, make sure the benchmark window is active (you can do this even if the cursor freezes) and press
Alt+F4 to force exit. If you get out of signal, replug the display cable. I have never needed to reboot with Unigine crashing. If you crash, reset the V/F-curve and find the highest stable clock.
7) Post your maximum stable core clock @ 1000mV 60C!
Below are some example 1080ti temp throttle ranges @ 1000mV.
Please note the throttle steps vary by the 1080ti model, VBIOS as well as the used voltage.
First temp throttle @ 36C, clears when you get back to 31C
Second temp throttle @ 51C, clears @ 46C
Third temp throttle @ 66C, clears @ 61C
Fourth temp throttle @ 81C, clears @ 76C
Therefore, 1949MHz @ 45C equals to 1936MHz @ 60C, so you can also post results if you got e.g. watercooling and can't get between the 55C-63C range.
Edit: I just noticed different cards & VBIOS throttle at different temp points, so in order to get comparable results we have to run the test @ 60C.
I'll start with my results:
Card #1:
1936MHz
Card #2:
1962MHz
Card #3:
2012MHz
The game is on for the Golden Chip!
How to do it:
Card #1:
1936MHz
Card #2:
1962MHz
Card #3:
2012MHz
