Help with new lens
11 Jul 2004
Neptune
We have a Canon EOS 1300D DSLR Camera with EF-S18-55 DC III F3.5-5.6 Lens - which has been a great starting point but the lens is limiting (having to be close to subjects to get decent shots).
Can you recommend a lens that would allow us to take pictures from further away (up to 15/20m) and be able to zoom and capture great shots? I don't understand a lot of the jargon used in lenses!
I've seen the 'Canon EF 75-300mm f/4.0-5.6 III Lens' for about £100 - would this be the one for the job?
If you are shooting handheld you will likely benefit from some image stabilisation. I would recommend the Canon EF-S Telephoto Zoom Lens EF-S - 55-250mm - F/4 - 5.6. Will blow your budget out of the water a bit if you buy new but you may get frustrated trying to use a telephoto lens without IS...
You can pick them up used for circa £100...........
A few here for £129 from MPB:
https://www.mpb.com/en-uk/search/?www-product-search=55-250mm&www-department=all
That canon lens is awful. (75-300) I wouldn't wipe my dog's arse with it.
It's not even remotely sharp, and is just generally nasty.
I'd look for a second hand Tamron 70-300 Di VC USD and add another £50 or so to the budget. Won't regret it.
Thanks for all your help. I wasn't maxing out at £100, just that's one i had found.
This one new looks ideal. The IS sounds like a definite requirement as it will be hand-held most of the time.
Thanks again. Ill check out that Tamron one as well. Cheers.
