AIO Noise Check
  • Thread starter Thread starter LiE
  • Start date Start date
Sent to a webnote, it's way too loud. Like a water garden ornament. OK if you're into the sound of running water I suppose!
On the advise of OcUK support I have rotated my case around and upside down to remove any potential air locks. Seems to have done the trick although moving the case in this way wasn't easy!
Seems to come and go. You think it could be too much air in the loop?
There shouldn't be much trapped air in a sealed AIO. Flipping cases etc is normally what you end up doing on custom loops to work air bubbles out, the fact you said it made a difference likely means there is a tiny bit of air in the unit.
I'd imagine it'll settle after a while. Let it run for 24 hours or so, even stressing it a bit (i.e putting the cpu under load) to get the fluid temp up and work it's way around the pump and rad etc.
