Burning DVD files to disk to play on a regular DVD player
19 Jun 2009
Can anyone help me out here.
I've just created a DVD using some free software called DVD Flick, i've created the files and it's made a folder with AUDIO_TS and VIDEO_TS folders inside.
I want to burn these above folders to a DVD disk so it can play in a regular home DVD player. I have burnt these folders to a blank DVD using Windows 10, however when I try and play the DVD in a regular DVD player the disk will not play.
Can anyone advise what i'm doing wrong, or what is the correct way of burning AUDIO_TS and VIDEO_TS folders to a DVD.
Many thanks
When you create DVD with DVD flick you should have selected the option either to create .iso or burn directly to disc.
However you should be able to burn the files to a disc and for them to play as a dvd. What's you've done is burnt them as a data disc.
You need to find a burner that will burn them as a dvd disc. I know Nero can do it, not sure about free burners tho.
I only use imgburn. But like I said don't have this problem as I create the .iso in DVD flick then burn it.
Hi, thanks for your reply.
I'm going to try burning the .iso directly from DVD flick to the DVD, i'll let you know in about an hour (it's a large video file).
