Estate cars aren't better in every way at all. SUVs are safer for a start, easier to load kids into, and the 3rd row in an SUV is a lot better than the 3rd row in an estate car.Apart from a higher seating position and perceived wealth of having something bigger than anyone else an estate is better in every way.
Also in a lot of cases the SUV is mostly a generation behind compared to its estate counterpart as it is almost always the last in a marques lineup to be replaced.
I've already posted this a few posts above your post but the data backs it up - there are far fewer deaths in SUVs than other cars.Your first two points are an opinion and not fact. It is far easier to load dogs in the back for example and it will be easier for a child to get into a lower car. I fail to see how SUVs are safer. Estates will have better handling, better braking, better acceleration and less likely to roll over. All good attributes to have when looking at safety. Also if you need a car with a 3rd row of seats you might as well get a van or the snip.
If you had the choice of a Range Rover or a RS6/E63 4 matic estate I know which I would rather have.
They aren't safer, they are much more likely to roll over in an accident or even while trying to evade a crash in some of them.
Some of them (and MPVs actually) looked really hairy on the moose test.
Yes, they're twice as likely to roll over. But rollovers aren't the majority cause of death and serious injury so your point within a general safety framework is null and void, even before we consider the rollover potential of the said SUV in the OP.
SUV's are on the same floorpan as estates in most cases how are they more safe because said floorpan is higher up? There is more to safety than taking an impact. Impact avoidance is just as important. An estate will have better brakes, acceleration and stability in this area like for like.
Lamborghini Uterus, where Chelsea Mums stick their kids. Lamborghinis are supposed to be mental not sensible, like this.
I mean, just look at it's arse end. Mental!
