so my card is getting hot even at idle, the temps seem okay but its just the back plate thats getting very very hot.
I know the back plate is there to take the heat away from the GPU but would a PCI double fan slot do anything to help towards this?
If so can you buy a double fan that runs from the PCI slot or do you still have to 4/3 pin connect them?
Many thanks guys
Many thanks guys
