Future upgrade thoughts: 120 Hz 4K, HDMI 2.1, 10 GbE
1 Apr 2014
Aberdeen
My current rig (see sig) is entirely satisfactory but there are big changes due next year, mainly HDMI 2.1 and 120+ Hz 4K monitors. The former will put an end to the Gsync / Freesync issue as well as HDMI vs Displayport; the latter will make 4K gaming that much better. So I'm expecting to make a full refresh next year. I expect that Nvidia's Volta and AMD's Vega refresh will support HDMI 2.1; Nvidia GPUs already support 4K120. I fear my biggest challenge will be choosing between 4K @ 144 Hz and 5K @ 100 Hz. I'll probably go SLI / XF because a lot of the older games support it.
I also expect to be changing the CPU and motherboard. I'll probably go for a Ryzen or Threadripper build for the extra PCI Express lanes so I can have a 10 Gb ethernet card without crimping the GPU(s).
All this is, of course, subject to change as products emerge.
Any criticisms?
Quartz,
I agree with your line of thinking.
I built my PC in 2012 to support 1080p 60Hz gaming. I'll upgrade my PC when I feel there is a significant reason to do so. To me, that would be a PC that can support 4k video at 120Hz.
But, I don't know if all of the pieces will fall into place in 2018. Obviously - as you point out - HDMI 2.1 must be established in the entertainment industry - and, I'm not seeing a lot of announcements to support thinking it is going to be viable within the next year. I hope it does - that would be great.
Otherwise, my 6 year old PC comfortably supports every possible need I can think of and I see no reason to build a new PC.
I enjoy running 4k, 60Hz video on my 6 year old PC using a 49 inch Samsung 8000K HDTV.
I'm thinking that video cards and monitors will come first, being premium products, and high-refresh 4K signalling is already here in Displayport 1.4. But if I have to wait an extra year, so be it.
Why will HDMI 2.1 put an end to "the FreeSync/GSync issue"?
There are a couple of motherboards that already have 5 GbE built-in, I'd expect that number to rise with any new motherboards next year (e.g. Z390 or a potential X470). Quite a lot cheaper than buying a separate card in most cases.
Because it has variable sync built in.
Good point. Let's hope so.
So does DisplayPort 1.2a, it doesn't help with the FreeSync/GSync war since the device needs to support a certain standard too. Hopefully the adoption of HDMI 2.1 will help force nVidia to support Adaptive Sync but by itself I don't see why it'd change anything.
