Lets say a game is just too demanding. How does 1080p look on a 4K monitor? Is it as good as on a 1080p monitor? (thinking of the 4to1
that's rubbish I can get 60 on a 1080 at 4k in Destiny 2.4K at the highest/high presets will only be possibly with 30fps lock for the latest games with a 1080. I gamed on a 1080 up until earlier this month.
Newer games with scaling also helps massively. As someone said above you might have to drop as low as 70%.
The jump in performance required from 1440p to 2160p is just massive. 1070 can do 1440p and the 1080Ti does a decent job at 2160p. The 1080 sits in between but is closer to the 1070.
https://www.geforce.com/whats-new/guides/destiny-2-pc-graphics-and-performance-guide
Destiny 2 is a very well optimised game and 4K is only really possibly with a 1080Ti at 60fps (required for a shooter like Destiny 2).
It's f
you said high/highest. I know you can, from experience too.60fps lock on Highest? No you can't and I say that from experience.
Don't think it is even possible to get 60fps average.
edit:
As well as Nvidia's own guide, lots of other review sites will confirm.
60FPS is easily achievable if you turn down the right settings on most games.
dont have it.I'd say you'd have to go to High completely.
Good luck running AC Origins at 4K60 by simply turning down a few settings.
dont have it.
but you said
https://www.gamersnexus.net/game-bench/3096-destiny-2-gpu-benchmark-launch-performance-uplift
last graph, 73.5 average, on a 1080 on high
Did not the OP ask is it possible if he dropped from ultra to high?
Seeing as most games are old then definitelyRealistically can I game at 4K with a 1080 if I drop from ultra to high and drop AA (or down to 2x) in most games? Anyone any experience?
Its also at stock, my card boosts to 2083 and running an 8700.Still not a 60 lock in that chart (but I'll accept the dips can be ignored in most cases). That is completely on High.
Destiny 2 is the best case scenario because it is so well optimised. Take a look at other games like AC Origins.
I would much rather use a resolution scaler than drop things like texture quality.
Heck I'd argue a 980 Ti can do 4k pretty well once overclocked my 1550mhz and 8.4ghz on the memory for over 400gb/s handled 4k very well.
i would say more like Medium for 60FPSRealistically can I game at 4K with a 1080 if I drop from ultra to high and drop AA (or down to 2x) in most games? Anyone any experience?
