- 21 Oct 2012
If the policy is not to allow neck scarves or other loose fitting items either then I don't see a problem here.
A hijab IS a loose fitting item and I think the attendant is in a no win situation here. If they allow a head scarf then why not a neck scarf.
If the attendant had also been asking other customers to remove loose fitting items then there is continuity of the rules being applied.
I think a lot of people don't have a clue what they are talking about though. Do they know the difference between a hijab, niqab and burqa?
A hijab is literally the least offensive piece of clothing you can think of. It's basically the same thing your granny would wear when it was common IN THIS COUNTRY for most folks to wear something on their head when leaving the house.
Why does everybody have to polarise over Muslim women these days. You're either white knighting and over protective or you're a closet bigot. There's no middle ground these days.
