Random internet drops... looking for ways to log when internet goes down.
9 Aug 2009
Internet
I keep getting random internet drops during the night and day which doesn't help when hosting servers and people can't connect to them so i am looking for ways or getting a program that can log to a file when the internet is active and when it goes down, help is very much appreciated.
I've been dabbling with Python tonight so I wrote a Python script to do this. To run it:
1) Install Python if you don't already have it (https://www.python.org/downloads/)
2) Copy the below script to a text file and save it somewhere as networkcheck.py
3) To run it, open a command prompt, change the directory to wherever you saved networkcheck.py and the type py networkcheck.py
It will check the state of the network connection evey 60 seconds (you can change this period to a different amount by changing the waittime variable in the script). It will log the results to c:\logs\networkcheck.txt. You'll need to either create the c:\logs directory or change the script to write to a different directory. Just CTRL-C to stop it.
Code:
import datetime
import os
import time
filename = "c:\\logs\\networkcheck.txt"   # Output log file name
hostname = "www.google.co.uk"             # Host name or ip address to ping
waittime = 60                             # Waits 60 seconds between checks
lastresponse = 1;
response = 0;
file = open(filename, "w")
while True:
    response = os.system("ping -n 1 " + hostname + " > nul")
    if response != lastresponse:
        if response == 0:
            status = "Connected"
        else:
            status = "No network connection"
        logmessage = "[" + datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S") + "] " + status + "\n"
        file.write(logmessage)
        file.flush()
        lastresponse = response
        time.sleep(waittime)
It will write a "Connected" or "No network connection" message every time the network connection is lost or reconnects. It won't log messages if the status stays the same (e.g. it won' continually log messages every minute - it will only log them if the status changes).
Sample output:
Code:
[2017-12-18 00:32:36] Connected
[2017-12-18 00:35:36] No network connection
[2017-12-18 00:36:36] Connected
Code:
import datetime
import os
import time
lastresponse = 1;
response = 0;
while True:
        if response == 0:
        else:
        file.flush()
Sample output:
Code:
Or you could create an exe for him so he doesn't have to worry about installing python, setting it up etc :)
I'd also run multiple pings out, see if you can see what is failing exactly. Is your line dropping, modem rebooting or something else funky going on. By pinging an internet address (say Google's DNS servers) and your inside gateway IP you'd have an idea of which is failing.
Also, what router do you have? If it's aftermarket you may have logs on there that'll give you an idea of what's going on.
Well true. But as I wrote it at midnight I fancied some sleep rather than either convert it to an exe or rewite it in a compiled language. Python is a couple of clicks to install and it also means he can easily change the destination host, filename and sleep time.
But by all means convert it to an exe for him with py2exe if you have a few spare mins.
it's the old teach a man to fish addage ?
I am still not unconvinced that a ping-out should be complimented by an external service checking your access eg. other folks may use different dns servers. so ping-out measures may not be reciprocated, or your http server is unable to respond.
Routerstats may do what you want. It polls your router and plots dsl sync speed and noise margin. Depending on the cause of the problem it may be more useful than pings.
if you want more details (of where things might be going wrong)
replace the ping in my batch file
with either
tracert
or
pathping
