No it isnt pointless as i explained. Not that either solution is acceptable, but halving the cpu speed changes the usage of the big and little cores and the smaller cores ARE more efficient even if they take longer to do something. that's the whole reason they exist in the Big.little architecture.
Big.little is more about loads and types of workloads, they aren't all just uniquely more efficient. They are more efficient in scenarios that the load doesn't outweigh the performance. IE for basic/low workload that can fit into a 1.2Ghz clock speed where running at 2Ghz wouldn't improve performance but would waste clocks then it's more efficient to run on the lower clocked cores. If however you have a heavy workload then it becomes more efficient to put that load onto the higher performance core so it completes more quickly. That is pretty much the point of big.little, splitting workloads to the appropriate core.
In reality in day to day use there are some times you'll need slightly higher performance, other times you need lower performance. Having lower performance because they force you onto the lower performance cores is, well, it's selling you a big.little chip but only allowing you access to the little cores after a certain amount of time, if that isn't advertised it's entirely and utterly inappropriate.
More importantly, before the battery is reduced all the workloads that are already more efficient on the little cores should already be on the little cores and all the workloads on the heavier cores should be more efficient on the heavier cores, so they are pushing a heavier workload to a less efficient core which makes no sense.
More importantly, people are reporting this more on older phones which didn't have a big.little setup, only the last couple phones have big.little. But again the idea of selling you a phone that achieves a certain performance level, and then removing that performance level at a later date is utterly absurd and more importantly, not standard in the industry. Do laptops reduce cpu power as the battery degrades, do any other phones, to mp3 players, do dvd players, do basically any battery powered devices decide to half available performance when the battery gets worse, nope. It's standard in the industry for users to know batteries run out and need replacing but entirely non standard for users to expect their devices to artificially limit their speed just because the battery holds less charge.
I'd be entirely fine with Apple doing this if they told people upfront they would do this, but they don't. You can't subvert industry norms completely without telling people and then expect people to think it's okay.
