- 2 Aug 2016
Allow me to clarify. Corsair make very good PSU’s, I have one in my main rig and it’s fantastic. I’m speaking specifically about the CX series. It’s a budget PSU.
And allow me to do the same, it isn't cheap and Corsair are not about making poor quality components. Unless it is damaged I wouldn't assume it was the cause of the issues.
Andi.
A budget PSU isn't necessarily cheap or unreliable.Cheap PSU…
Ok so let's go back to what you originally said.
Andi
If you insist on dragging this away from solving the op's problem. Yes. Although I don't see the point you make. You've had one that caused you a problem, that's not going convince me they are all bad. If so Corsair would no longer be selling them and certainly OCUK would not stock them any more.I’ll ask again, have you owned one?
Andi.
And I believe you've had one break on you. My mining rig is running 24/7 on a 650W Corsair PSU.Sure you have. Merry Christmas!
Andi.
