suggestions?
9 Feb 2009
Hi all,
looking to upgrade my gaming rig (mostly playing Destiny 2 at the moment, some CSGO). Currently running I7-3770k, Asus P8Z77-V Z-77 with an MSI Radeon R9 290X gfx card. I'll be looking at 1440p screen (either 27 Inch 165Hz with G-Sync or 32 Inch 144Hz without sync).
I'm planning on saving my current PSU (SuperFlower Leadex Platinum 1200W) and my sound card (Sound Blaster Zx), plus the below...
My basket at Overclockers UK:
Total: £1,828.93 (includes shipping: £0.00)​
Hi all,
Thought about using the Strix board ?
For the above price can get an Aorus 7 with better on board audio , along with £40 steam voucher .
***Just saw you had blaster Z which is roughly the same snr output but should have the edge
Total: £464.08 (includes shipping: £11.10)
Also, can get an Aorus gtx 1080 11gbps forb£520 odd . 11gbps are worth it due to overclocking to 12gbps and pulling clearly head of newly released gtx 1070 Ti
Since you like bequiet case , have you seen the Base 700 case ?
Basically smaller version of 900 but with subtle RGB
Total: £188.69 (includes shipping: £11.70)
If you can push to the Silent Loop 360, do it. More room to cool the i7 K which can be hot when overclocked . Also run it at 100% in bios, doesn't make a sound like Asetek AIO units other brands use​
In all honesty I'd be tempted to OC the 3770k, get an SSD if you don't have one (or a bigger one if you do), upgrade to 16GB Ram if you haven't already and go for a 1080 or 1080ti. Your CPU will still be very capable with an overclock and most games are still GPU limited. I doubt you'd notice a huge difference for your £1500+ compared to what you already have. I'd certainly recommend a graphics upgrade anyway so pick up said 1080/ti and slap it in and see how you go? You'll double your FPS according to Anandtech GPU bench and that's just with a 1080. A 1080ti is almost triple your current performance.
Another method is grab gtx 1080ti now and see what Ryzen + brings out next year . Not too long ;)
If they can hit 3600hz ram speed and 4.4/5ghz overclock - should be interesting
Already have a SSD (Samsung 840 EVO) and 16gb of RAM, the 1080ti is tempting (for either a new build or upgrade to current) if i can find it on a good deal. (currently running a 3 x 24inch 1080p eyefinity setup, however i will cut down to a single larger screen)
Does AMD have much on the horizon? I believe the next generation of Ryzen are out in Feb next year(?) however i think it might be all hot air and lack the performance kick that it needs once the dust settles. Are they really going to launch an all out attack on the high performance end of the market?
thinking about the Asus MoBo's, i will need to do a little bit more research on the features they both come with. i suspect that downgrading the MoBo to save some money (maybe 1080ti gfx upgrade) might be wise.
I can squeeze in the silent loop 360 for the improved cooling, i have read some nice reviews of the Dark Base 900 and like the little sound proofing details they add (not to mention the modular nature of the case and cooling options). I'm not massively sold on glass panels and lights etc (my PC sits under my desk currently, i would rather go for quiet then show off.
TBH its more of an itch then a need, i have the resources to upgrade and the last overhaul was in 2012. I have a friend who could do with a gaming PC so i have a good use for the old parts after i upgrade (partly why i'm going for a full system with case rather then partial upgrade).
700 is based on 900, being modular , even more so as well as inverted but loses the 5.3" bays . Glass is a good sound insulator. Better then just solid panel bit not matching panels found in that case that has sound dampening material on top
To good boards that free up cash and can handle 5ghz overclock nicely
Total: £325.08 (includes shipping: £11.10)
Might free some cash for Ti
Total: £1,389.48 (includes shipping: £10.50)​
Spoke to there customer support guy who was very helpful, it seems like there was some issues, hitting refresh a few times would randomly change the price from standard to deal price. in the end i hit order when it was at the deal price and it went through ok.
It brings it down to under the 2k mark which is good news!
Awesome ! Get a build log going.
And completely forgot to mention, thermal Grizzlie paste !
no build log yet, i have some pictures (mostly early on, i got distracted and forgot to take pic's once i started).
I am having a few issues, i'm failing to get a POST. When i plug it in, i get lights on the MoBo, and the standby power LED is orange, however when i press the power switch on the front of the case the fans spin up for 1-2 seconds then the whole system powers down. It won't do anything if i press the power switch again, however if i switch the power supply off and on again i can repeat the above process. Also if i leave the system long enough (30 seconds or so) the MoBo led's will turn off and the power switch will become unresponsive again.
none of the "POST State LEDs" which indicate a problem are alight (Boot, VGA, DRAM, CPU) and there are no bleep codes (no speaker attached so no surprise).
I have checked the connections, Jumpers and reseated the GPU and RAM (in different slots), i have tried replacing the kettle lead. I have no reason to believe the PSU is faulty, I bought it in Feb 2014, but RMA'd in Feb 2017 (Asus Surge Protection on my old PC). However it's been unused since sent to me (by the time the RMA was returning i had replaced it with a spare and didn't get around to swapping it back).
Any suggestions? Faulty MoBo or PSU?
Recommend doing the basics . Out of the case, onto the Mobo box.
Everything apart and reseat key parts
CPU back in, check orientation.
One Stick of ram in manuals recommended slot , believe that's slot 2.
24 pin and CPU 8 pin in
Forget any drives
Leave the GPU out.
Connect case power connector
Trying powering on and see if you can get into bios. If not try other ram stick
You did go Asus right ? And if your still in 14 days should be able to hopefully get brand new one if OCUK detect a fault.
I know gigabytes own RMA you can send in your board, ram and CPU chip.
Ifs worth asking if above or other members trouble shooting methods down work, if you could send all 3 components in - nothing worse then then sending a part back saying it's fine, and you've got to send off a different one to find if that's the cause
Try that 'spare ' PSU . Gain with GPU . Just need to get into bios
Confirmed its a duff PSU. I pulled my old power supply (850w XFX) from my old rig and installed it and everything is operating as expected now.
What kind of power will this thing draw? i had no worries with a 1200w superflower PSU, however with a smaller XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply...
Think of the ratings as MPG on a car when you top up £10 in, going to get better returns in theory . As with superflower King units, you don't have to use the most expensive part to hit titanium. Heck even tiny SFX units can hit gold ...
850w should be fine for that system, just have to check your model how much is supplied through the main rail .
Might be your RMA didn't go well
There isn't to much savings for your elect bill as you jump from one award to the next, you'd find savings if you went from a bronze 500w to a titanium 500w. But most of the time, higher energy units tend to use better components
You actually lose eff rating if you have a massive watt unit and actually only draw half of it
