- 19 May 2005
Personallysed it.
* p.s : I purchased the X just because the screen had more real estate than my 7 plus
Jokes?
Personallysed it.
All that just to replace a battery lol
Takes 5 seconds on some non-apple phone.
Fixed for you.
Good luck replacing the Samsung Galaxy S8’s battery in 5 seconds. Same with most other flagship phones these days.
Not much that can be done about the past. At least Apple have now clarified the situation.
What we don’t yet know are Apple’s motives. You are assuming you know the motives already, but I suggest you remain open minded until we see the actual result of the various investigations that have now started.
You could, but you’d have to prove that that was Apple’s intention. And we have no evidence of that. Apple have publically stated this fix was to prolong the life of a device not shorten it.
Lol. Blind faith much? Apple doesn’t do anything by accident. I’m sure this was just a little whoopsie, all in the past, promise not to do it again!
Come on.....
#3 They're trying to hide what is effectively a hardware fault with the battery to save them the embarrassment and expense of replacing millions of batteries
Yes batteries degrade, usually 3-5 years is their lifespan. But e.g. for my phone I can just buy a new one for under £4 on ebay lol
Ah but you cant get genuine apple lithium ions for £4. Those special lithium-ions cost £79.
/sarcasm.
£25. Fitted.
/sarcasm or not
Price dropped on 28th December.
Ah yes the most 'radical' and 'most advanced' lithium ever.You mean iLithium. Totally new and invented by Apple.
???You dangle a hook and he bites on command.![]()
Batteries do degrade and there are ways to deal with it.
Slowing hardware isn't even a new thing, many devices do this if they know they are low on charge but you are informed of this ability in advance.
It simply shouldn't have been done in an underhand way.
There are three options I can see.
#1 Apple intentionally chose a battery they knew wouldn't last to get customers to upgrade sooner or buy additional batteries by way of down-clocking.
#2 They're lying and there is nothing wrong with the batteries
Neither option is good.
Or
#4 All mobile manufacturers run there batteries far too close to their theoretical maximum with little buffer at the top and the bottom end to get every last min of screen on time/call time. These batteries run in this way are only really decent for 500 cycles or so which most people seem to get though in 2 years or so. Just happens to be the same length of time of most modern phone contracts where people then tend to upgrade. It's like they have done some market research into this or something?
Battery degradation in Li-Ion is more than just cycles though:
The deeper you discharge it, the quicker it degrades. If you fully discharge it, it dies. This is very important.
The higher you charge it the quicker it degrades.
If you store it fully charged, the quicker it degrades.
The quicker you charge or discharge it, the quicker it degrades.
Too hot? Degrades quicker
Too Cold? Looses capacity.
A degraded battery is more than just lost capacity, it effects everything:
How quickly you can charge it.
How much power you can draw.
How much capacity you have.
How it performs when hot or cold.
If you google search phone turning off at 30% there are so many results and there not just Apple.
The Samsung i8910 HD from 2009 still has the original battery, it still works, it's not heating up much when in use and the benchmark results are the same as the day it was bought, the battery life is a bit crap though but you would expect that.
How are iPhone's from 2009 coping?
It’s fair to say that the i8910 HD doesn’t push its battery anywhere as hard as a more modern smartphone pushes its battery.
